登录向日葵需要开放哪些端口
登录向日葵需要开放哪些端口
Home Page AweSun Product After work, Party A let the draft be revised again? You don't have to go back to the company to deal with it easily!
Update Date:2025-09-12 03:52:13
What do you designers fear most about working to move bricks on a daily basis? After work, Party A/leadership suddenly asked us to revise the draft for sure on the list, and sometimes there is actually only a small revision, but also need us to return to the company, which is not much free time off work is tossed away.
So is there a plan that allows us to remotely complete the revision and other work, as far as possible to reduce the pain of temporary overtime? Awesun remote control is a good choice.
Using Awesun remote control, we can not only carry out revision, large file export and high-performance AI to generate materials from the workstation host of the remote control company at home. It can also quickly return the material and complete the editing when going out for shooting tasks. At the same time, it will not be limited by the performance bottleneck of the equipment around it, and can complete all kinds of work efficiently.
Just recently, Awesun also released a new version of "Awesun 16", which is equipped with many new features, which can help designers and friends to complete their work remotely and improve efficiency. Here we will take a look.
The performance is further enhanced: the editing of the modified picture is not stuck, and the color feedback is real.
In this major version update, Awesun 16 has implemented a full range of performance upgrades, allowing remote desktops to open faster and with lower latency.
The new high-performance mode will not only support up to 8K60 frames and 4K144 frames, AI image quality enhancement will also be added to make the picture more clear and detailed.
At the same time, Awesun housekeeping skills have not been lost: it supports 4:4:4 true color mode, supports tablet pressure mapping, supports cross-system remote control, especially supports macOS control, and can run mac applications Windows.
In general, using Awesun 16 for remote design, drawing modification and video cutting can achieve smooth experience without blocking, real picture color restoration, and smooth operation as local, so that the remote working experience of designer friends will not be discounted.
Add "Super Desktop": Seamless Remote Control, Like Local Open Productivity Software
There is always a "remote control window" in the traditional remote control, which makes us a little unaccustomed. The "super desktop" function added by Awesun 16 solves this problem.
The super desktop can directly map the application of the remote controlled computer to the desktop of the local master computer, and open PR, PS, Blender and other productivity tool software like the local, with no delay in touch.
At present, the Awesun 16 super desktop function is open to melon seed members and free users for a limited time: all you need to do is install Awesun 16 and click on the top text link to get it.
"Small K" File Flash: Say goodbye to tedious operations and easily synchronize materials
Designers work remotely, which inevitably involves the transmission of a large number of material files. If the operation of this step can be simplified, the efficiency will naturally be greatly improved.
Now, Awesun 16 is a new online "small K" that supports flash file transfer.
We only need to drag the file to the floating window to send the file to another computer, without opening the remote desktop or entering the file transfer interface, and the whole process is operated locally, without the need for third-party transfer software to upload and download, making the operation more convenient and efficient.
"becoming a secondary screen": the screen is not enough? Just find a notebook
All designers know a truth, that is, the more screens, the better. One screen for the main operation interface, color palette, material browser, etc. are best on another screen, so that the work is convenient enough.
However, sometimes there is no multi-screen condition for working at home. At this time, if we have a notebook or tablet computer that is not used for the time being, we can use it as a secondary screen.
The "become secondary screen" function on Awesun 16 supports turning the equipment around us into the extended screen of the host computer. we only need to click the "become secondary screen" button on the right side of the Awesun software equipment and wait for the system to establish a connection.
After the connection is successful, the main control terminal interface will display the prompt "the secondary screen has been opened"; At this time, the screen content of the controlled terminal will be projected to the main control terminal in real time and can be used as an extended display.
Summary:
The update of Awesun 16 is a good news for designer friends. These new features can help us to complete the design work remotely. The improvement of efficiency means that the bad work takes up less personal rest time, and the enhancement of business ability will also bring potential promotion and salary increase.
Finally, I suggest that you might as well use Awesun 16 as a daily remote tool, which will be very useful.
At present, Awesun 16 has been officially launched Awesun official website, and major application stores are on the shelves one after another. Welcome to search for "Aweray Awesun" to download and upgrade and experience the above new functions!
No matter where...
Awesun 16 compr...
· Awesun 16 comprehensive upgrade, remote debugging, cross-platform development easily!· How can severe weather enterprises improve their disaster recovery capabilities? It is important to have a fast remote control scheme.· Telecommuting enhances disaster tolerance, typhoon weather Aweray Awesun telecommuting solution insurance business· Several elements for enterprises to build technical support solutions: efficient remote, software customization, management traceability, work order access· How to use AweSun Q1 to remotely control BIOS and various devices?· How does AI application empower enterprise IT operation and maintenance? Analysis of Aweray Awesun AI Capability
· Exploring the Benefits of remote access to computer from ipad· Cloud Gaming Software: How AweSun Transforms Remote Play· Simplifying Remote Computer Management with AweSun· Best Remote Control Software for Seamless Remote Access· The Power of Mac Remote Control: Enhancing Productivity and Effortlessly Managing Multiple Devices· Software to Control Another Computer: Enhancing Remote Access and Control
Introduction to this article
Summary:
